2005 Ford Explorer Brakes
2005 FORD EXPLORER
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
QUASANTON
Hey guys. I took my vehicle in to just have new tires put on. When they guys were changing my tires they said the brakes were pretty worn and should be replaced. Since I was already there I said ok. They also said the rear rotars needed replaced. Again, I was already there so I said ok. Once all that work was done and I drove away I heared a noise that sound like I was running over those safety strips on the side of the highway but when I braked it went away. I took it back to them and at first they said they didn't know what was wrong, then they said they put the pad on backwards...the left on the right and the right on the left. SO, they fixed that and NOW it makes that same sound but only when I FIRST apply the brakes and then it goes away. Took it back and third time and they have no idea what is wrong with it. Got a second opinion and they said it sounds like faulty brake pads, but original company refuses to change them out and said they are fine. PLEASE HELP!!!
Nov 29, 2008 at 6:27 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be demanding a new set of pads as they did admit to fitting them up incorrectly.
Mark (mhpautos)
Nov 29, 2008 at 6:36 PM
