Does anyone know where the rear ABS sensors are located? I can't seem to find any electrical wiring going to the rear wheels.
Jul 31, 2008 at 8:55 AM
WALTBERC
MEMBER
I found it. It's on top front of the differential. If the car is not on a lift and it's just jacked up it can be seen by removing the rear passenger wheel and it can also be removed from here. Or you can crawl all the way under the car where it can be seen and also removed. The cost from the dealer is about $30.00.
