2004 Ford Explorer Metal inside intake manifold
2004 FORD EXPLORER
180,000 MILES • 6 CYL • AWD • AUTOMATIC
WAYWARDJEEPGUY
The motor in my explorer locked up. I took it to the dealer who dropped the oil pan and discovered metal shavings in the oil pan and bottom of motor and said the motor needed replaced. Remanufactured motor ordered from Ford and installed. The engine knocked so they had to order another one (no cost to me). So, onto my question... I get a call from the dealer saying that when the original motor locked up it shot metal shrapnel up into the intake and now i need a new intake at a cost of $400. Does this sound correct?
Thanks!
Update: dealer used a borescope and it seems there may be part of a valve embedded up inside the intake.
May 7, 2010 at 3:24 PM
It's possible. Are they able to clean it out or was it damaged?
May 8, 2010 at 12:52 PM
WAYWARDJEEPGUY
No. I asked the same thing and apparently it's damaged because something which appears to be part of a valve is embedded up inside the intake.
May 8, 2010 at 7:12 PM
THen it sounds like it should be replaced. If it is damaged like that, it can't be repaired. Sorry, I wish I had better news.
May 8, 2010 at 7:25 PM
