coolant leak thermostat housing?
2004 FORD EXPLORER
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
ERNS210
i have a coolant leak that wont stop moving...i have replaced the thermostat,the thermostat housing,radiator,waterpump and hoses and i still have a leak behind the pump...what could it be? and how do i fix it
Jul 21, 2010 at 10:16 AM
More then likely you have a distortion on the mating surfaces so what I would do is remove the gaskets and replace them with gray RTV.
Here is a guide that will help with replacing the water pump and thermostat again which is what you need to do in order to replace the gaskets:
https://www.2carpros.com/articles/water-pump-replacement
Below you will find the process from the manual which will help with the detail.
Let us know if you have other questions. Thanks
Jul 13, 2021 at 6:02 PM
