Okay, bear with me. When I picture what happened, that should have fixed it unless more air got into the system that we think. You may have to bleed all 4 wheels.
If you do, start at the RR, LR, RF, LF. Also, when you depressed the caliper, did you force the brake fluid back into the master cylender, or did you bleed the excess fluid at the caliper?
Also, I asked this before, but have you tried adjusting the rear brakes to help?
Jun 3, 2010 at 12:43 PM
