2003 Ford Explorer turn signal & hazard lights
2003 FORD EXPLORER
89,487 MILES • 6 CYL • 4WD • AUTOMATIC
MKRISE77
I can't seem to get my turn signal or hazard lights to work. I have changed the fuse, relay under the dash, replaced the turn signal assembly & checked to see if there was a fuse I was missing under the hood, but the blinkers or hazard lights still don't want to work. Is there something I am missing. Please let me know what I am doing wrong with this problem & how I can solve it on my own. Thank you for your time in this matter.
Mar 17, 2009 at 1:55 AM
BMRFIXIT
  • 19,053 POSTS
Step on brakes do all brake light work
check flasher and replace
if not suspect multifunction switch and or wiring
check for missing fuse
Mar 17, 2009 at 6:01 AM
