2003 Ford Explorer ring and pinion replacement
2003 FORD EXPLORER
AHNESTI
Drive Train Axles Bearings problem
2003 Ford Explorer 6 cyl Two Wheel Drive 108,00 miles
I have a loud whine which seems to be coming from the rear differential. It gets louder when I press the gas. In doing research, I believe i have to replace the ring and pinion. What is the average cost of this repair and how difficult of a repair is it?
Oct 13, 2010 at 11:05 AM
WRENCHTECH
  • 20,761 POSTS
It is not that simple at all. You would likely be replacing all the bearings also and assembling and setting up a differential requires some expensive specialty equipment and extensive knowledge. You might want to consider just purchasing a used differential to make it easier.
Oct 13, 2010 at 11:25 AM
CRAYFORD1
I have a Ford Explorer 2003 4WD V6. Dealership is charging $1,680 for ring and pinon replacement and $500 for front right wheel bearing replacement. Price included labor.
May 7, 2014 at 3:02 PM
