I have had my Explorer in the shop. they replaced sensors, relay switches & different types of fuses. I even had the turn signal assembly changed to no avail. The problem is that when I either shut the driver door or push the lock button on the keyless entry pad the park lights come on & remain on. I then have to unhook the battery to keep the battery from running down. Is this a simple fix or a big problem? Any help would be greatly appreciated. Thank you for your time in this matter.
Oct 19, 2009 at 10:37 PM
