2003 Ford Explorer Multiple probelms
2003 FORD EXPLORER
93,000 MILES • V8 • 4WD • AUTOMATIC
THIS_ONE_GUY_4U
  • 4 POSTS
i have a whining nosie coming from engine when in park i think it might the air intake but not sure only hear it sometimes. i had my car scanned at autozone and they said it was my egr valve...i replace egr valve with oem one and i also replace the egr valve sendor still has probelm when i unplugged the air sensor next to the throttle body the check engine light went away when i plug it back in the check engine light comes on again..im'm also getting mpg so i recently did an oil change and spark plug change also a fuel filter change and did all my diff. fluids, transmission fluid. etc...still getting bad gas mileage my tires are perfect and inflated corredtly and i just replace my air filter i think it has something to do with the check engine light...give me any info
Mar 7, 2009 at 5:52 PM
BLACKOP555
  • 10,386 POSTS
get the exact code that is showing up and tell me what it is in P**** format that way i can truley tell you what is probably wrong.
Mar 8, 2009 at 12:58 PM
THIS_ONE_GUY_4U
  • 4 POSTS
well i just came back from autozone and the code came up P0122 throttle position sensor but i had to unplugged it to do the spark plugs before that it was the egr code if you have multiple code proebelms will it just show one or all
Mar 8, 2009 at 2:45 PM
BLACKOP555
  • 10,386 POSTS
if there was more then one code showing up then it would display all them. the only code that wont show up is if you have more then one missfire, thin it would show up as random or multiple cylinder missfire.
Mar 8, 2009 at 8:26 PM
THIS_ONE_GUY_4U
  • 4 POSTS
well i replaced my throttle position sensor and unplugged my battery i drove 30 miles and it hasnt shown up yet hopefully this is is but i cant say that cause its a FORD.......
Mar 8, 2009 at 10:46 PM
BLACKOP555
  • 10,386 POSTS
it should be good, it should have shown ujp now if it was a persistant problem. dont just blame it on the ford!
Mar 9, 2009 at 8:18 PM
