I have three problems. All fuses appear to be working.
#1 Driver door lock/unlock not working, yet the passenger lock/unlock works. Recent issue, past month
#2 BIG PROBLEM PAST WEEK: Can not remove key from ignition, key is not turning back completely to position 1. The buzzer continues going off even if all doors closed (and door ajar light remains on). I can remove the key (turn completely back to position 1) ONLY AFTER disconnecting the battery. I called my local Ford mechanic who said they'd never heard of such a problem and it would cost me $99 just to have them run a test!
#3 Not sure if the door ajar light is connected to the main problem because the door ajar light had been staying on over the past six months and may be connected to the back tailgate (a replace job Ford did that's not "been normal" since the job was done).
Dec 1, 2008 at 8:48 AM
