2003 Ford Explorer Headlight replacement
2003 FORD EXPLORER
DGRETKA
Electrical problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic
How is the assembly removed to access the bulb?
Jan 4, 2010 at 12:32 PM
You should be able to access if from under the hood, behind the headlight assembly. Check to see if you can find the light socket. It should unscrew out.
NOTE: Don't touch the glass part of the new bulb. The oils from your skin will cause the bulb to create a hot spot and it will burn out faster.
LEt me know if you find the socket.
Jan 6, 2010 at 10:36 PM
