2003 Ford Explorer clatter from valve drive
2003 FORD EXPLORER
17,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMPOPP
Overheated the motor and had the cyl heads rebuilt (warped). Reinstalled the heads and it started fine and runs smooth.... But there is a clatter coming from inside the valve covers near the timing chain area. I have run it for two hours now and it's not getting any quieter. The chains are tight and looked good when reassembling it. Good oil pressure. The dealer says I need a new motor. I don't need a motor, I just need to fix the immediate noise problem. Your help is appreciated.
Oct 5, 2010 at 8:39 AM
Have you tried adjusting the rocker arms?
Oct 5, 2010 at 10:27 AM
