2003 Ford Explorer Auto lock, easy exit seat, auto lamp del
2003 FORD EXPLORER
112,889 MILES • V8 • AWD • AUTOMATIC
JRGILES
The above subject and the reverse sensing system are not working.
The RSS turns off automatically when the truck is put into gear.
Jul 17, 2009 at 10:08 AM
MERLIN2021
  • 17,250 POSTS
Check to see if your brake lights and reverse lights are in working order, then try this for at least the Autolock feature.
1. Turn ignition key ON.
2. press the power door unlock control on the door panel three times.
3. Turn the ignition key from ON to OFF.
4. Press the door unlock control three times.
5. Turn the ignition key back to ON. The doors will lock and unlock.
6. Press the unlock control. The horn will chirp once upon successful
toggling of the Autolock feature.
7. Turn ignition to OFF.
You must complete steps 1 through 7 within 30 seconds or the proceedure
must be repeated. If the proceedure must be repeated, you must wait 30
seconds.
Jul 18, 2009 at 5:49 AM
