2002 Ford Explorer window regulator replacement
2002 FORD EXPLORER
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
M372000
How do you remove the window retaining bolts on the right front window and then repalce the window regulator
Aug 22, 2009 at 7:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
raise the front door window glass to the half-open position. remove the front door trim panel. remove the inside glass weatherstrip. remove the watershield. disconnect the lock rod at the latch assembly. remove the bolts (some cases may have rivets) that attach the glass to the regulator. raise window up to full up position and support the window glass. disconnect window motor electrical connector. disconnect regulator and motor assembly from the door frame. remove regulator and motor assembly through door opening. installationg is reverse of removal procedure.
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_124.jpg
Aug 23, 2009 at 1:42 AM
