2002 Ford Explorer whine when a/c is on
2002 FORD EXPLORER
101,000 MILES • 6 CYL • 4WD • AUTOMATIC
ELESTER12
Hello. I own a 2002 Ford Explorer. My A/C does not cool well unless I�m driving at a constant speed on the highway with the RPM's around 2000-2300. When I come to a stop the A/C efficiency reduced and when I start to accelerate the A/C lines seems to whine/howl. The whine changes with different RPMs. The whine also affects the cooling performance. I had my Freon level checked twice. The dealer told me they don�t know what it is. Any advice would be appreciated. Thanks!!!
Aug 20, 2009 at 2:13 PM
AIR CONDITIONING PROBLEM: NOISE
Noise from the compressor usually means the compressor is on its way out. But noise can also be caused by cross-contaminated refrigerant (operating pressure too high), air in the system or the wrong type of compressor lubricant.
Aug 20, 2009 at 2:18 PM
ELESTER12
I had the system recovered and then recharged. I was thinking it might be the compressor clutch or the expansion valve. Could either of those cause the whine noise while the a/c is running?
When replacing the a/c compressor what other parts should I replace?
Thanks
Aug 21, 2009 at 7:29 AM
Could be the clutch, you sure the belt is not slipping-Just replace the compressor itself. Have you tried listening to it real close to ID where the whine is coming from.
Aug 21, 2009 at 12:19 PM
