2002 Ford Explorer rear window on driver's side
2002 FORD EXPLORER
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
JUST PLAIN ROG
must have slipped off the track...window will not raise up....the motor can be heard when pushing to raise or lower the window...
how hard is it to take the door panel off and put the window back on track?
Nov 22, 2008 at 12:05 PM
DAVE H
  • 13,384 POSTS
Rear Door Window Glass
Removal and Installation
Remove the rear door mounted speaker.
Remove the inside glass weatherstrip.
Remove the watershield.
Connect the window control switch.
Lower the rear glass to access the regulator to glass clamp hold down screw at the bottom of the door.
NOTE:Some vehicles may use rivets to attach the glass to the regulator.
Remove the bolt that attaches the glass to the window regulator.
Remove the upper run channel from the frame of the door glass opening.
Remove the applique on the rear door.
Remove the screws.
NOTE:Slide the glass through the outboard side of the rear door (24630).
Remove the rear door window glass (25712).
To install, reverse the removal procedure.
Nov 22, 2008 at 8:30 PM
