2002 Ford Explorer Rattle at 1000 RPM
2002 FORD EXPLORER
12,900 MILES • V8 • 2WD • AUTOMATIC
BRTTBFD
My Explorer has started to make a rattle. This only happens when the engine is at 1,000 RPM's. I've narrowed down the area where the noise is coming from to the under side of the engine on the passenger side. I also bought a stethoscope and believe it's coming from a box where the lowest pulley is attached (cannot find a diagram to know what this pulley does). I've just changed the serpentine belt and still it makes this rattle. No check engine light and the vehicle performs normal. Any help is greatly appreciated, thanks.
Jan 1, 2010 at 4:44 PM
The bottom pulley is the crankshaft. There really isn't anything there that can rattle. If you tap on the exhaust system with a rubber mallot, can you duplicate the rattle?
Let me know
Jan 2, 2010 at 12:40 AM
