2002 Ford Explorer Power Window Regulator
2002 FORD EXPLORER
RILEYSMOM
The power window regulator has went out on my 2002 Ford Explorer. The window is completely down. How do we raise the window manually to disconnect the window from the regulator? It is raining here, and help would be greatly appreciated.
Sep 4, 2006 at 8:26 PM
NOS
  • 320 POSTS
try this first turn the key on hold the window button in the closed spot. at the bottom of the door towards the hing with a rubber malet or something solid hit the bottom of door or even on the door panel towards the front at the hing area this may jar the motor enough to make it go up you may only get one shot make sure your holding the button. hope this helps.(NOS) 8)
Sep 6, 2006 at 7:23 PM
