oil sending unit, where is it?
2002 FORD EXPLORER
120,250 MILES • V8 • 2WD • AUTOMATIC
Oil gauge is acting funny, it will be fine and then sometimes it just goes to nothing but the motor sounds and runs fine.
Jan 25, 2010 at 4:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The oil pressure switch at left side of engine block. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 25, 2010 at 4:14 PM
2CP-ARCHIVES
  • 4,540 POSTS
2002 Ford Explorer mileage: 45,000. Where is the oil sending unit located on this model?
Mar 7, 2019 at 3:22 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
The oil pressure-sending unit should be next to the oil filter.
LINDA_COLE03
I am looking for a detail diagram as to where I can locate the oil pressure switch, can you help me with this. it is a 6 cylinder motor. I bought the part because I am get erratic readings on the gauge now I have no idea as to where it goes, is it next to the oil filter and if so, where?
What liter engine ?
FIXITMR
  • 9,990 POSTS
is that a 4.0?
Mar 7, 2019 at 3:23 PM (Merged)
LINDA_COLE03
I do believe it is a 4.0 engine
FIXITMR
  • 9,990 POSTS
ok all i can find right now is this. it's right by/behind power steering pump. hope it helps
FIXITMR
  • 9,990 POSTS
found another.
BREADMANJOHN
Oil pressure sticks with cold start,after a few seconds it jumps up to normal.
DOCFIXIT
  • 18,828 POSTS
Next to power steering pump in block
FIXITMR
  • 9,990 POSTS
if you see blank image(thumb)click anyway it should pop. my internet glitched on me.
JDL
  • 16,098 POSTS
It should be next to the power steering pump.
LINDA_COLE03
Thank you very much. I do believe this is going to help me find it. I appreciate your assistance.
RIVERMIKERAT
  • 6,110 POSTS
Linda, were the images helpful? Did you get the oil pressure sending unit changed out?
MEONEIL
Engine problem
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic 100K miles
Can you tell me where the oil pressure sending unit is located?
The engine oil pressure switch is located on the engine next to the power steering pump-see below
https://www.2carpros.com/forum/automotive_pictures/12900_oil_pressure_switch_1.jpg
STUKNBAMA
Where is the oil sending unit on a 2001 Ford Explorer with the v6 OHC?
I know it needs replacing, but can't locate it.
Thanks in advance
STUKNBAMA
ANYONE out there?
STUKNBAMA
Does anyone have any idea on where this is located?
LOVESCARS
  • 359 POSTS
usually on the block semi close to where the oil filter is located it will look partially like a spark plug with a wire on top. If may also be leaking motor oil if no good.
PERKINS1982
where is the oil sending unit located on a 1995 ford explorer xlt 4.0 liter v6
MHPAUTOS
  • 31,937 POSTS
It is located next to the power steering pump on the block, see pic for general view.
Mark (mhpautos)
XWICKEDXLULLABYES666
Engine Mechanical problem
2000 Ford Explorer 6 cyl
where can i find the oil sending unit in my car?
It should be near the oil filter. If you can't find it, let me know and I'll try to find a picture.
[quote:2502234ef1="Jacobandnickolas"]It should be near the oil filter. If you can't find it, let me know and I'll try to find a picture.
Joe[/quote:2502234ef1]
ok we found it and we bought a new one but they sold us the wrong one. we have no clue exactly what one we need...
OCRIM504
  • 21 POSTS
Where is the oil pressure sending unit located and is it difficult to change?
If its a 302CID/5.0L engine its located next to the power steering pump and its not a difficult job to do.
JOERACCIO
Where is the Oil Pressure Sensor Sending Unit located on 1996 Ford Explorer?
it's under the hood, lower engine area, above oil filter, mounted in lower driver side of engine block. Here is a picture of it. THe picture is for a car that has a gauge. If you only have a light, it looks very similar, but has some minor differences. Let me know if this helps.
https://www.2carpros.com/forum/automotive_pictures/249084_aa_1.jpg
DHAMILTON
Engine Performance problem
1996 Ford Explorer Four Wheel Drive
where is the oil pressure sender?
ROB2008
  • 258 POSTS
Find your engine below .
* 2.3L, 2.5L engine-left side rear of the engine, below the cylinder head
* 3.0L engine-top front of the engine, on the intake manifold
* 2.9L and 4.0L engine-top left front of the engine, on the intake manifold
* 4.0L SOHC engine-top front of the engine, on the intake manifold
* 5.0L engine-top front of the engine, on the left-hand side of the camshaft synchronizer.
HOTMINNIE
where is the oil sending switch located?
BMRFIXIT
  • 19,053 POSTS
Its on the engine
almost next to the power steering pump
good luck
DNDC16
My Oil gage keeps bouncing up and down when I am stopped or the rpm drop below 1000. I have been told that the oil sensor/sending unit might be bad. I could not locate it. Any ideas?
BLACKOP555
  • 10,386 POSTS
it could be the sign of a possible failure of the sending unit or a loose wire, but most likely the pump is going, i would take it in and have the oil pressure tested to make sure everything is functioning properly
DONCAT
Where is the oil sending unit on a 2001 Ford Explorer Sport with a v6
Mar 7, 2019 at 3:24 PM (Merged)
CHEVY22
  • 1,375 POSTS
HI
the oil pressure sendind unit is located on the engine next to the power steering pump , the low oil/tem sensor is on the left side of the engine at the oil pan
