Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Explorer
Interior
Interior Lights
2002 Ford Explorer Courtesy lamp in door mirror
2002 FORD EXPLORER
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNY BAKER
MEMBER
1 POST
FOLLOW
How do I remove the lens covering the courtesy lamp, located under the mirror on esch front door, to replace the bulb?
Nov 24, 2009 at 10:14 AM
RICKMAR
CERTIFIED EXPERT
Remove the two screws from the underside of the mirror. The two screws are diagonally across from each other. Remove the bulb housing pictured below.
Remove and replace bulb and lightly tighten the two screws. Good Luck; Rick
Nov 24, 2009 at 11:53 PM
