2002 Ford Explorer Blown Engine
2002 FORD EXPLORER
247,000 MILES • 6 CYL • 4WD • AUTOMATIC
AJM
2002 Explorer 247000 miles, enigine starting making a ticking noise that increased in tempo with acceleration, I pulled off the road to check it out, after checking fluid levels, I tried to start it, but it would not crank over. The mechanic shop says it is a blown engine, primarily the timing chain causing the right side of motor to not work, and the engine has lost compression, he says the best recourse is to replace the motor for $5800. Can this engine be repaired, rebuilt, or because of the high mileage, is this the end of the road for this explorer's engine. Engine has had routine tune-ups, oil changes, no major repairs ever. First time for a major engine repair...ever! What should I do?
Nov 24, 2008 at 8:07 AM
AUTO REPAIR HELP
I would say you could get a second opinion but that's not very easy with your car in the shop. I would also suggest you check out the reputation of the repair center you have gone to.
Nov 24, 2008 at 9:23 AM
