2002 Ford Explorer 2002 Ford Explorer Wheel Bearing
2002 FORD EXPLORER
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
ODINM
  • 4 POSTS
I was wondering if the following indicates a bad right or left rear wheel bearing:
@ 55+mph a loud oscillating vibration occurs. The noise is comming from the rear. And from what I can tell its the passenger side wheel.
another point to note is when i make a slow left turn (on the highway) the noise is unmisteakably louder, and the noise goes away when turning right (again on the highway).
Does that make it clear-cut that it's the passenger side? Or might it be the driver's side??? Are there any simple tests to check if the bearing is bad?
I was told which ever side you turn to and the noise is made, the opposite side is the bad bearing. Any help would be appreciated!!!
May 16, 2008 at 7:36 PM
BLACKOP555
  • 10,386 POSTS
what you state last is true, noise on passanger side when turning that way drivers is usually bad.
to check jack up the vehicle and wiggle the top and bottom of the tire, push the top toward the other rear tire and pull the bottom away from it, then pull the top and push the bottom, if play is noted theres a bad bearing.
May 17, 2008 at 3:32 PM
