When I put my truck into 4WD, I hear a thump when driving. I think my transfer case gears are broken. What is the cost to fix or replace?
Dec 10, 2009 at 1:00 PM
CERTIFIED EXPERT
Are you sure the noise comes from the transfer case and not the front axle? Does the 4wd work?
Dec 10, 2009 at 9:17 PM
BEN123
MEMBER
It does work, however there is a loud thumping noise when it is engaged while I drive. Mechanic said it probably is a broken tooth on a gear inside transfer case and wants to rebuild/repair it for $1500!
