reset check engine light
2001 FORD EXPLORER
DWALTHERS51
recently had mass air flow replaced and engine light came back on a few days later, how to I reset it? need to pass emission test
Apr 23, 2010 at 4:49 PM
There are a couple issues with this. First if the light came back on then the issue is not resolved so we are not going to be able to just clear the code. We are going to have to fix the issue so the light will turn off.
Next if you do clear the code and not fix it then you are going to have what is called a P1000 code. This is nothing more than telling the emissions testing places that the codes were recently cleared, and the monitors have not passed yet to ensure there are no issues.
Here are a couple guides that talk about this:
https://www.2carpros.com/articles/scan-test-is-incomplete-p1000
People used to always just clear the codes and then pass emissions when there are no codes, and it was a way to game the system so the government made the OEMs to put this code in place so that they couldn't be tricked any more.
Let's start with getting the code and we can go from there. Thanks
May 25, 2022 at 10:41 AM
