2001 Ford Explorer Front end shake at speed
2001 FORD EXPLORER
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
DONBELEME
I noticed a shake before replacing my tires and thought it was from one of them being out of round. I replaced all 4 tires (they were due for it anyway) and thought that would be it. Not even close. It rides smooth as silk until it gets over 60mph. Anything above that and it really begins to wobble. Front end alignment? Done! That was my next step. No changes in how the truck reacts. Worn shocks? Done! Brand new Monroe Sensa-Trac shocks all the way around. Now I am looking at wheel bearings but when I had the truck up and the wheels off to replace the shocks, I did not notice any play in the bearings. What are your ideas for my next thing to try. I had the tires replaced and front end alignment done at our local tread quarters here in Chesapeake, Virginia. They have a pretty good standing with the BBB but I am always looking for a second opinion. Thanks!
Jul 23, 2010 at 12:00 PM
KHLOW2008
  • 41,814 POSTS
Hi donbeleme,
Thank you or the donation.
If the shaking occurs whether accelerating, cruising or decelerating and at certain speed range, then it most probably is due to the wheels not being balanced properly.
Get the tire shop to recheck the tire balancing.
The other possibiity would be worn steering linkages or control arm bushes.
Bad universal joints of the front drive train would cause the problem as well. Check the propeller shaft U-joints for stiffness or wear.
Jul 23, 2010 at 1:32 PM
