2000 Ford Explorer Vent blows hot air
2000 FORD EXPLORER
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZUKER
When the car is warmed up and the vent is turned on it blows out hot air as if the heater was turned on. Is there a valve/solenoid/thermostat that is not closing?
Apr 10, 2010 at 5:05 AM
I recommend having the blend door actuator checked. If it doesn't work properly, it will cause this problem.
Apr 12, 2010 at 7:17 AM
ZUKER
Thank you, that was it.
Apr 14, 2010 at 4:05 PM
I'm glad you got it taken care of. Let us know if you have questions in the future, and thank you for using 2carpros.com.
Apr 14, 2010 at 10:08 PM
