2000 Ford Explorer how involved to change shocks
2000 FORD EXPLORER
114,500 MILES • 6 CYL • 4WD • AUTOMATIC
CORNPATCH1943
can i change the shocks from underneath, orwill i need to go under the hood, and inside the cargo area
Jul 6, 2008 at 9:23 PM
BLACKOP555
  • 10,386 POSTS
do you have a strut model? if so you can take out the assembly but you wont be replacing the shock unless you have the proper tools and a spring compressor.
it unbolts from the top under the engine compartment, and under, BEHIND the tire.
Jul 7, 2008 at 9:05 AM
CORNPATCH1943
no struts,it has shocks all around
Jul 7, 2008 at 9:29 AM
BLACKOP555
  • 10,386 POSTS
turn of air suspension switch, raise support vehicle and support lower control arm
then remove the upper shock nut wash and insulator then remove the lower retaining nuts, compress and remove it.
Jul 7, 2008 at 7:25 PM
