2000 Ford Explorer hesitation low rpm
2000 FORD EXPLORER
170,000 MILES • V8 • 2WD • AUTOMATIC
RCLARE
I just had a cracked radiator replaced. when I got the vehicle back there is a hesitation accellerating from a stop. there appears to be a smell in the car that started this morning. the repairman did a 40 point inspection is there a possibility that this broke something else?
May 10, 2010 at 11:06 AM
If he disconnected the battery when he replaced the radiator the computer probably has to go thru a relearning process or there's a loose connections somewhere
May 10, 2010 at 4:25 PM
RCLARE
it turned out that the air flow sensor was disconected for rad repair. plugged it back in and all is well.
you were right.
Thanks
May 10, 2010 at 8:51 PM
