2000 Ford Explorer freeze plug
2000 FORD EXPLORER
161,000 MILES • V8 • AWD • AUTOMATIC
DUSTINDOWNS
can you tell me where the freeze plugs are located?my truck froze and i found the plug on the ground.also i have a brass screw type plug to replace it,are these good? thank you
Dec 12, 2009 at 6:39 PM
The freeze plugs are on the sides of the engine block. I just hope the block didn't crack. As far as the new plug, if it is rubber with the brass nut, yes they are good.
Dec 23, 2009 at 10:40 AM
BERNARD FREEMAN
So my Ford explorer ran hot I replace the thermostat and gasket but when I poured antifreeze back in it was coming out from the bottom. Where is it coming from
Feb 7, 2019 at 5:37 PM
Hmm hard to say but here is a guide that will walk us through how to find the leak.
https://www.2carpros.com/articles/car-is-leaking-coolant
Feb 8, 2019 at 1:01 PM
