1999 ford explorer xlt, the oil filter is ripped open?
1999 FORD EXPLORER
MBH
MEMBER
1 POST
FOLLOW
I cannot remove my oil filter. I believe it was put on improperly when i had my oil changed last. how can i get it off?
Mar 10, 2006 at 2:37 PM
JPAM
CERTIFIED EXPERT
well if you can get at.. use a good size screw driver (flat or phillips it dont matter) and use a hammer to pound it trough.. this will give you more levridge and should brake lose.. hope that helps.. jess s.
Mar 10, 2006 at 11:33 PM
PEPPERMRJ
CERTIFIED EXPERT
Huge channel lock pliers arounfd the heavier base plate of the filter. A little heat from a heat gun could help also. :!: [b:c31744c718] No torch![/b:c31744c718] :!:
Good luck and let us know.
Mar 11, 2006 at 9:35 PM
JPAM
CERTIFIED EXPERT
NO torch.. come on you take all the fun out of it...
:shock: Big driver and hammer does work too. :lol:
