Well if they weren't connected it would be peeing all over from the pump pumping the fluid. Get as close to the pump as possible (ideally at the pump) and disconnect the line and energize the pump. The pump should be squirting. If it isn't the pump is bad or fluid can not get into the pump on the inlet side. If not there is a restriction further up the line. For that compressed air can probably blow through the restriction.
Mar 10, 2008 at 6:02 PM
