Transmission fluid
1999 FORD EXPLORER
132,000 MILES • 6 CYL • AWD • AUTOMATIC
HARDEEPONE
Thank you for your time and help. I'm about to do a transmission fluid change on this Car but I cannot seem to find the location for the new fluid. There isn't a separate tank visible for the new transmission fluid. How do I fill it up?
Jul 4, 2010 at 7:23 AM
That is correct. There is no separate tank for this fluid. We need to fill the transmission using this process in this guide:
I am attaching the info below from the manual but here is another guide that will help with checking the fluid after you are completed.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please see the info attached on how to service the unit that talks about how to fill the unit as well.
Let me know what questions you have.
Thanks
Jan 25, 2022 at 5:55 PM
