1999 Ford Explorer passenger door will not open
1999 FORD EXPLORER
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIRK2580
hello , my car has power door locks, i can not get the passenger side door to open , i can see the threaded post pop up , but , not enough to pop, i do not want to force the inside handle , can it be the actuator ???
Feb 8, 2010 at 7:41 AM
Chances are the actuator is the problem. But you need to remove the door panel to check to see if the linkage it attached or damaged.
Feb 11, 2010 at 1:41 PM
