1999 Ford Explorer cruise control
1999 FORD EXPLORER
103,000 MILES • 6 CYL • AWD • AUTOMATIC
GLEESON79
  • 9 POSTS
cruise does not come on any more, have checked all mini fuses and like fuses ,have not checked relays. what needs fixed to make it come on and work again? thanks
Feb 22, 2010 at 2:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
does the CC indicator light come on at all when switch is engaged? how about the brake lights, are they still working fine?
Feb 22, 2010 at 2:45 PM
GLEESON79
  • 9 POSTS
no cc light on, brake lights work
Feb 22, 2010 at 2:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
perform diagnostic test on the CC system by following steps below. let me know what code/s you retrieve, if any.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1731.jpg
Feb 22, 2010 at 3:00 PM
GLEESON79
  • 9 POSTS
goes into self diagnostics - after pressing "ON" light comes on then goes out- but resume does not make light come on, nor does coast or set/ accel
Feb 22, 2010 at 9:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have to be certain you are pressing ON within 5 seconds of entering the diagnostic
Feb 22, 2010 at 9:51 PM
GLEESON79
  • 9 POSTS
does run through on-resume-coast-set/accel, have not yet gotten visual confirmation that cable moves, dont know if im getting out of vehicle fast enough
Feb 23, 2010 at 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you can just watch the gas pedal, no need to go under hood and watch
Feb 23, 2010 at 12:12 PM
GLEESON79
  • 9 POSTS
thanks im on my way now to run it through diagnostics
Feb 23, 2010 at 12:51 PM
GLEESON79
  • 9 POSTS
went through diagnostics, light flashes twice , break pedal does not move
Feb 23, 2010 at 1:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, this indicates a fault with the brake pedal position switch, most likely the switch itself is faulty but first ensure that the wiring is connected properly and not damaged. the BPP switch is located on the brake pedal support, above brake pedal .
Feb 23, 2010 at 2:03 PM
GLEESON79
  • 9 POSTS
put new switch in ,ran diagnostic test cant tell if gas pedal moved ,all other lights flash. havent driven it yet to try speed control. reverse quit working,snow causing problems pushing it out of driveway.
Mar 3, 2010 at 12:53 PM
