1999 Ford Explorer Brakes Master Cylinder
1999 FORD EXPLORER
10,800 MILES • 6 CYL • 2WD • AUTOMATIC
EOLIVE
I need to replace my break master cylinder. Are there any special toos I need to replace it?
Aug 27, 2008 at 1:13 PM
DOCFIXIT
  • 18,828 POSTS
Not really a line wrench is needed to prevent damage to flair nuts. Ratchet with extension and deep well socket.
Be sure and bench bleed new m/cyl there should be couple of plactic tubes and instruction in box.After install bleed system rears then front. Protect paint break fluid does a number on paint.
Thanks for donation
Let us know if you need further assistence
Aug 27, 2008 at 1:27 PM
