I have a 99 explorer that I purchased. They said the timing has jumped, so before pulling the motor I have changed the spark plug, fuel filter. It will hit and run a little off starting fluid. So I started looking at the fuel system. I noticed that the voltage going to the inertia switch is only 6.70 volts. I get the same volts at the fuel pump. I changed the relay and still get the same volts. I can jumper the power across and get 12volts and the pump runs. Why am I losing 5.3 volts through the relay?
Jul 3, 2010 at 11:34 AM
