My 2wd/4wd light is flashing.I looked under the car and saw fluid on the front pumkin.Could it be the gaskit and very low on fluid?
Sep 9, 2009 at 3:20 PM
CERTIFIED EXPERT
The differential has nothing to do with the 4wd. Will the transfer case shift from 2 to 4wd?
Sep 10, 2009 at 8:26 AM
DPEF1
MEMBER
[quote:f6487ca7de="Jacobandnickolas"]The differential has nothing to do with the 4wd. Will the transfer case shift from 2 to 4wd?[/quote:f6487ca7de]
I have the same issue and now I cannot shift fro 2wd to 4 wd. Thoughts?
Sep 27, 2009 at 8:52 PM
CERTIFIED EXPERT
Does the car have electric shift 4wd or manual? IF electric, check the 4wd actuator on the transfercase to see if it is getting power when you have a helper push the button for 4wd. If it is, the actuator is most likely bad. ...Not uncommon.
Sep 27, 2009 at 9:30 PM
DPEF1
MEMBER
It is manual, so you have to turn the knob to change to 4WD...
Sep 27, 2009 at 10:52 PM
CERTIFIED EXPERT
You need to check to see if there is power to the actuator on the transfer case. If there is power, the actuator is bad. This is not an uncommon problem.
