1998 Ford Explorer Transmission works then quits working
1998 FORD EXPLORER
112,000 MILES • 6 CYL • 4WD • AUTOMATIC
KELLERRACING
When I put my explorer in gear, forward or reverse, it goes alright for a minute, but then starts slipping and then completely stops pulling. After I turn the engine off for a few minutes, the transmission will pull again for a minute and then stops pulling again.
I was told that there might be a plastic part inside that has broken and is getting sucked into a pick-up line, thus causing this problem.
Does this sound reasonable, and what is my next step?
Feb 16, 2010 at 4:11 PM
I know when the explorer was introduced in the early 90's, they had a retaining clip that would break and cause problems. Is the trans fluid clean and full? Has the check engine light ever come on?
Feb 17, 2010 at 8:48 AM
KELLERRACING
The fluid is clean. Darkish, but not burned. The engine check light has never come on. This transmission problem happened, and within 25 minutes I had it parked so that I wouldn't do any further damage. Jim
Feb 19, 2010 at 10:56 AM
Either the trans control module is bad or a retaining clip has broken on one of the clutch packs.
Feb 24, 2010 at 11:00 PM
