1998 Ford Explorer Speedometer not always working
1998 FORD EXPLORER
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
GGCROSSON
My speedometer on my 98 Explorer will work for a few miles then stop. when car sits a while it will work again. i saw a post you answered earlier and that post was just like my problem. i followed what it said to do and got same result. i turned key on and held Cruise OFF button, i got one flash. then i pushed Cruise ON button, i got one flash. but nothing else with the sequence you stated. i checked the fuse to the right of the steering wheel, #10 7.5 amp. and it was good? is that the right fuse to check, at that point i am lost as to what to do next. Does that tell me what i need to replace?
thanks for your help
Gary
Feb 12, 2009 at 10:36 AM
RACEFAN966
  • 5,029 POSTS
Continue reading as now you should unplug the cruise servo and connect your multil meter between term 3 and ground and drive it to 30 mph and see if there is a volt reading set your meter to AC volts. If no reading then VSS is no good if you do have a reading then the Cruise servo is bad.
Feb 12, 2009 at 10:48 AM
