I have had zero previous symtoms. I turned the key to start the truck in the morning and it just cranked. I thought it was a fuel issue but can hear the pump. Next, I checked for spark and found that I had none leaving the coil pack.
Everthing seems to be functioning and with no previous symptoms I find it hard to believe my coil pack could abruptly go.
Could the security system malfunction and cut my spark. The symtoms are the same if I accidentally try to start the truck with a door key. I did try two different keys that are coded and neither worked.
I also tried to disconect the battery to reset th computer in hopes it was the security system.
Should I try to replace the coil pack first. Can I reset or disconect my security system.
Any help would be greatly appreciated.
Gary
Gary
Aug 13, 2008 at 8:56 AM
