I want to disable the auto lamp in my '98 Explorer. I've located the five (5) wires that lead to the auto lamp mirror:
- White w/Pink stripe (Park Lamp Relay Control)
- Black w/Pink stripe (Reverse Input)
- Black (Ground wire)
- Light Green w/Yellow stripe (Power *Always Hot)
- Red w/White stripe (Inginition *Only Hot at start)
Which wire(s) should I cut in order to completely disable the auto lamp feature WITHOUT causing any problems with the manual switch on the dash? One (1) individual responded and advised that I should cut the "thin black wire", and he probably means the ground wire leading to the auto lamp mirror, but I'd like some additional concurrence or expert guidance. Thanks! Dan
Dec 21, 2009 at 3:07 PM
