1998 Ford Explorer how do i test to see if my injectors ar
1998 FORD EXPLORER
162,000 MILES • 6 CYL • 4WD • AUTOMATIC
ENOCHAHORNE
  • 8 POSTS
pretty sure the fuel pressure isnt right.and do the injectors haft to have a certain amount of pressure to operate?and how do i test to see if the injectors are pulsing?
Mar 11, 2010 at 11:38 AM
You need to check both. As far as the injectors, you need a noid light. It plugs into where the injector is pluged. It will pulse on and off when the power is sent to the injector. As far as the pressure, here is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Mar 13, 2010 at 12:58 PM
