1998 fuel pump changed pump checkd all relays replaced them all... Still having the fuse pop everytime i turn key on.. Im lost at this.... I have power to the intertia switch and power under the hood for the fuse and the relay all connections look very good i have power to the intertia switch when the key is engaged... then the fuse in the engine compartment blows everytime old pump was bad and the new one was tested before i put it in the tank.... Any suggestions i have checked wiring top to bottom... any feedback would be of much help...
Feb 13, 2010 at 6:08 PM
