What is the fuel pressure measured at the fuel rail? I got 30 psi at 20 inches vacuum and 38 psi at 0 inches. With the fuel pump removed from the tank in a bucket of fuel it reads 80 psi. The engine check light is on and it says all three O2 sensors have low/slow response. It has 102,649 miles and the fuel trim is 100%. I suspect the fuel pressure is low.
May 23, 2010 at 1:55 PM
