Unable to get the starter to crank, have replaced the old 65-650ah with a new 65-850ah. Everything works fine except, when i switch on the ignition, instrument lights come on fine for about a second, then dim dramatically as if shorted-out.
Is there a limiting fuse or other cut-out which prohibits the higher amperage ofthe new battery?
Dec 11, 2009 at 8:10 PM
