1998 Ford Explorer Battery replacement
1998 FORD EXPLORER
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISWEBSTER4276
Unable to get the starter to crank, have replaced the old 65-650ah with a new 65-850ah. Everything works fine except, when i switch on the ignition, instrument lights come on fine for about a second, then dim dramatically as if shorted-out.
Is there a limiting fuse or other cut-out which prohibits the higher amperage ofthe new battery?
Dec 11, 2009 at 8:10 PM
Hi chriswebster4276,and TY for the donation and Merry Christmas
Find the starter relay use a remote start or short out he S teminal on it to the battery side of the relay did the starter engages the engine? Let me know asap
The higher the CCA's on the battery the better you are for cranking purposes and cold weather enviroment below 32degs
Dec 11, 2009 at 8:33 PM
CHRISWEBSTER4276
[quote:7570db6f17="rasmataz"]Hi chriswebster4276,and TY for the donation and Merry Christmas
The higher the CCA's on the battery the better you are for cranking purposes and cold weather enviroment below 32degs[/quote:7570db6f17]
Hi "rasmataz", just need some clarifications.
Is the 'starter relay' what we (in UK) call the 'solenoid'?
If so, are you suggesting i just bypass the solenoid and establish whether the solenoid is defective?
Also, I guess the answer to my second questions is that there is no cut-out that would seek to limit this battery's higher amperage?
Happy Christmas to you and thanks for the rapid response.
Chriswebster4276
Dec 12, 2009 at 2:24 AM
Yes its the same thing and for limiting the voltage the regulator controls the alternator output-
Dec 12, 2009 at 12:07 PM
CHRISWEBSTER4276
[quote:08b72e17d9="rasmataz"]Yes its the same thing and for limiting the voltage the regulator controls the alternator output-[/quote:08b72e17d9]
rasmataz, thanks for your help. it turned out the coil was burned-out, maybe due to the increased current from the new battery, and created the short once the ignition was switched on.
chrisw
Dec 12, 2009 at 9:51 PM
