1998 Ford Explorer abs sensor
1998 FORD EXPLORER
149,000 MILES • 6 CYL • 4WD • AUTOMATIC
WRAMPH
I was told I have a bad abs sensor in my right front wheel. I was told I have to change the rotor with the sensor because it isn't seperate. Is this true? Can't I just replace the sensor?
Jan 7, 2008 at 8:11 PM
CHAZ312
  • 8 POSTS
The person that told you that was wrong on two accounts...
1. It's not the rotor that the speed sensor is part of, but the wheel hub. A new one that will last you a few years can run up to about $225 for the part if you can change it youself. Get a repair manuel when you buy the part if you go that route.
2. You can change the sensor itself, but they run about $160 and you can only get them from a Ford dealler. This is a much easier repair, but you may find out latter that the hub needed replaced also. You should get the hub checked by a mechanic before you do this repair. :)
Jan 11, 2008 at 11:50 PM
