when I start the engine it sounds like an air vacim leak on top and the rpm's go up and down and sometimes the engine stalls.
Mar 4, 2009 at 3:20 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
This is sounding like a vacuum leak, start with checking all the vacuum hoses for correct fitting, cracking or damage, also you can use a length of hose as a stethoscope and listen around throttle body, manifold and you may hear the leak, try this first.
