1997 Ford Explorer Running Lamps
1997 FORD EXPLORER
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
JGABEL
We have a 1997 Ford Explorer and when the vehicle is turned off the running lamps don't shut off. We have to disconnect the battery to shut them off. I am not sure if I should be checking the multi-function switch or the headlight switch or if it would be something else. Could you tell me where to start.
Thanks
Jul 12, 2008 at 12:56 PM
KHLOW2008
  • 41,814 POSTS
Hi JGabel,
Check the relays first, should be underhood.
Jul 12, 2008 at 11:48 PM
