We have a 97 Ford Explorer 4.0 ohv. The check engine light is on and flashes when you go up a hill. It shakes and sputters when going up hill, and sometimes on a flat surface. When it is on a flat surface the engine rems up a little before it will shift. To get it to go you have to find the spot in the accelerator to give it gas. We so far replaced 3 oxygen censors, a fuel pump, the fuel filter, coil pack, a fuel injector, catylitic convertor, head gasket, lower and upper intake gasket, valve seals, spark plug and wires before head gasket was done, cleaned the maf sensor. We checked the codes and first it was a misfire on 4, then on 6. We are running out of money trying to find the problem please help.
May 26, 2010 at 1:55 PM
